i have a buring noise in the background of my download of monsters inc ,is there a way to get rid of this .
cheers anton
I've had the same problem with fast and furious.
First split the audio from video using virtualdub, then download Goldwave(I forget from where, do a search on google) Load the sound into goldwave. find a part of the movie where there's no other sound except for the buzz. Select the portion using a left and right click on the audio wave. copy the selection then click effects>filter> Noise Reduction on the menu. In the dialog select "use clipboard" and click ok, when it's finished the buzzing noise will be gone.
Merge the audio and video back using virtualdub
background noise in dvd (from .mov)
By nunsepofa in forum ffmpegX general discussionReplies: 6Last Post: 4th Mar 2012, 21:14 -
Dvd with background noise
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 11th Nov 2010, 10:58 -
Background noise removal - Please help!
By maurof78 in forum AudioReplies: 2Last Post: 3rd Oct 2010, 10:24 -
Background Static Noise..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 01:28 -
removing background noise
By pw29010 in forum EditingReplies: 2Last Post: 16th May 2007, 22:27
