Hi,
I used EZ CD creator 3.* to burn VCD and played on my DVD player without any problem. Recently, I tried EZ CD creator 5.* for VCD burning. The VCD was created successfully but would only played 10 plus minutes then stopped. I looked into the disks. In the one created with EZ CD creator 3.*, the *.dat file was put in the Mpegav directory. In the one created with EZ CD Creator 5.*, the *.dat file was put in the Segment directory. What is the problem? How to fix it?
Thanks!
Best regards,
F Chang
