I am trying to back up my copy of Disney's Pinnochio and smart ripper keeps stopping about 40% through the process. Unable to decript. Program gives three options retry, ignore, abort. I try "retry" and it keeps going to the next sector and giving the same error. Ignore just gives same problem at next sector. I can play the movie using windows XP media player fine. Have and no problems ripping other (non Disney) movies. Had same problem with other Disney movies. Does the DVD player software used (media player vs winDVD vs powerDVD) make a difference? Are there some settings that can be changed with smart ripper?
What OS are YOU using?
Are your ASPI drivers updated.
If you have XP please use SP-1
Try DECRYPTER 2.4 instead of smartripper
also, may be firmware of your DVD ROM that bites.. Try another
DVD-ROM or the burner itself if you can.
I use CREATIVE 2x player for the best regionfree ripping
also good is PIONEER burner itself
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
problems with Mac the ripper 3.0 R14i
By andyx181x in forum MacReplies: 12Last Post: 4th Dec 2007, 19:51 -
DVD Decrypter problems - I want the very best DVD ripper
By Lovepeaceguru in forum DVD RippingReplies: 3Last Post: 11th Nov 2007, 19:54 -
Problems with Mac Ripper
By AbelCastro in forum MacReplies: 7Last Post: 21st Jun 2007, 08:46 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
