Hi,
I have a DivX file with a stereo audio stream, and an external AC3 stream for the same DivX file. I want to eliminate the stereo stream (wich came with the video) and replace it with the multichannel stream. I'm trying to use Nandub to do it, but I'm having problems with the sync. I've played with the preload and interleave options, but it seems that I'm far from understanting clearly how these parameters work. The strangest thing is that the delay is not constant, the movie starts fine but the audio seem to go a little faster than the video and it keeps getting worse as the frames passes. I've used AC3Fix to detect problems with the AC3 stream, but none was found.
Anyone knows what can I do to solve this?
Thx,
Gustavo
Results 1 to 1 of 1
=- Slaughter =-
Stargate SG-1 Season 6 & 7 A/V Sync Problems
By slider5634 in forum DVD RippingReplies: 16Last Post: 24th Jul 2009, 19:21 -
[?] Audio Sync & Compression Problems. Trying to start a series.
By shibbuh in forum MacReplies: 2Last Post: 26th Nov 2008, 17:26 -
How do I compile AC3, ASS, AVC & Fonts into an AVI (or DivX)?
By Panarchy in forum Video ConversionReplies: 3Last Post: 25th Oct 2008, 21:41 -
Problems encoding from Vegas to Divx and AC3
By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 05:30 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
