If you are using the ATI TV Wonder card and are having problems with the audio dropping out or not being heard at all try this...
Don't use the audio connections on the purple dongle. Plug your RCA cables in to an apater (get one at radioshack) and then plug directly in to your sound card. I did this and the audio showed up each time. Even after closing and using different capture apps. You will probably need to set your capture apps to "line in". Also have your control panel audio options open as you might need to unmute a few things. Hope this helps.
My system:
XP Pro
Athlon 1.2 mhz
700(ish sdram)
Gefroce 2 GTS
Results 1 to 1 of 1
How to fix volume of an audio file
By Instant Martian in forum AudioReplies: 32Last Post: 8th May 2011, 04:55 -
How to fix audio in flv files
By Rebel1 in forum Video Streaming DownloadingReplies: 1Last Post: 8th Aug 2010, 17:24 -
how do I fix this audio
By Remyisme in forum AudioReplies: 7Last Post: 25th Oct 2008, 15:00 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
