Exactly what does "GET VTS Sectors" do in Ifoedit??????????????????
im not an expert on ifoedit but i do believe it makes the dvdr play on the standalone dvd.
thingimijig. -
I am not completely fluent with ifoedit but I think
Each sector contains 2024 bytes so a dvd will contain multiple sectors containing all the information (movie/menus/subtitles etc) making up the Gb space.
When you stream(strip) subtitles/audio etc then you reduce the amount of bytes and sector information.
So you are left with ifo files with chunks of data missing here and there and everywhere(dvd laser hunts for info).
By getting `vts sectors` it then looks at the original ifo files(that u ripped)
and checks that information with your newly created ones(because you have stripped bits out)they r wrong and rewrites the ifo files according to what u r left with so the internal linking is constant.
The above maybe wrong but that is my understanding in non technical way.If tomorrow doesn`t exist where shall we all be the day after tomorrow!!!!!!!!!!!!!!!!!!!! -
I have just found something on ifoedit.com that explain a little bit more on vts sectors.
Sectors Error While Burning
By rckowal in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 09:19 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 02:16 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28 -
Bad Sectors?
By whoisquilty in forum MacReplies: 8Last Post: 19th Apr 2008, 21:09 -
Bad Sectors..
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2007, 12:06
