I have 6.5Gig of home video i would like to transfer to DVD.
I have a DVD recorder and have the files in both AVI and MPEG 2
I have played with TMPGenc but if you lower the frame rate then the quality of the video suffers.
Can i convert them into a Divx format and then burn them as a DVD ?
Would the file size be smaller ?
Would the quality be maintained ?
Last but not least how, what program would you suggest and is there a guide.
I would appreciate any suggestions you may have
Regards
Nick -
Is your 6.5 gig when it is AVI or MPEG2.
What type of AVI is it, DV, uncompressed, huffy, divx is also a type of AVI.
Do not lower the framerate, if you want to reduce the size of your MPEG2 video you can lower the bitrate, this will also reduce quality but that is just a compromize you have to make. Use VBR rather than CBR encoding, this way the bitrate can be allocated more effectively.
Yes you can convert to DivX, for this you can use virtualdub. DivX can maintain excellent quality at a fraction the size of MPEG2. So you could maintain the quality whilst significantly reducing the size of the video. You could then burn this DivX video to DVD as a data disc. It would play on a PC with the divx codec installed, it would not however play in your DVD player.
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
DIVX player question
By slats7 in forum Video Streaming DownloadingReplies: 4Last Post: 25th Sep 2008, 07:10 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
DivX question
By didikai in forum Newbie / General discussionsReplies: 11Last Post: 18th Jun 2008, 20:22 -
Divx converting question
By KilinKind in forum Video ConversionReplies: 2Last Post: 15th Jan 2008, 18:25
