I've just created my first dvd-r, ripped from an original dvd.
Oh my goodness!
I only did the first twenty minutes, and stayed around the 4000kb/sec mark and wow!
What a difference over the scvd/vcd I'd been doing.
I'm using Virtualdub to capture and CladDVD, DVD2Avi and then TMPGEnc Plus to encode, and envisage getting around two hours of high quality per dvd-r.
Can I expect a signififcant loss in quality by sqeezing three hours on a dvd-r?
Much in the same way as I didn't like to span more than two disks when creating vcd/svcd, I'm prepared to scarifice some quality to fit my movies on one dvd-r.
Thanks,
Will
If you're thinking of getting a dvd burner and aren't sure if it's worth it, it is![]()
dont know much about tmpg but.
i have done lord of the rings with cce and i honestly cant see a difference.
thingimijig. -
Thanks for the postOriginally Posted by thingimijig
I'd be interested to lean how long your encoding time is with LOTR using cce.
Whilst I find TMPGEnc superb the encoding time is a little long, although I'm expecting a significant inprovement going from a Duron 800 to an Athlon XP2000+. -
i am only guessing cause i leave it running while i am in bed.
so saying that, doing a 2 vbr pass it should take no more than 7 hours thats using dvd2dvdr which needs cce 2.5 and ifoedit95.
when i wake i have a new m2v file, an ac3 file, a subtitle file and a chapter file if you require them.
all done automatically.
thingimijig. -
With my Duron 800, If I remember correctly, it was taking about three hours per one hour of film. I'll check out what difference my XP2000+ makes tonight.Originally Posted by thingimijig
I'm not sure I understand, are you saying it's all done automatically for you?Originally Posted by thingimijig
I have to open CladDVD to rip to hard drive (step 1), then I have to open DVD2Avi to convert VOB's to m2v and ac3 (step 3), then I have to open TMPGEnc to create my dvd mpeg2 file and finally (step 4) I have to burn to dvd-r using Ulead Movie Factory (Nero gave me an error message yet Ulead MF creatd it fine first time).
Everything is done individually.
Are you saying steps 1 to 3 (everything before burning to dvd-r) are done for you automatically when you set them before you go to bed?
You only have to burn to dvd-r?
Many thanks,
Will -
everything except the authoring (i use maestro).
then burn.
so thats another 1hour and half.
1800xp and 512 ddr.
thingimijig.
pm me if you need the program. -
So all this time I've been individually starting each programme, and I didn't need to?Originally Posted by thingimijig
Crikey!
Thanks,
Will
Thank goodness for more ram - old computer shines
By yoda313 in forum Off topicReplies: 14Last Post: 2nd Jun 2011, 18:03 -
1 film 1 language and nothing else bloating HD goodness - how is it done?
By The Big Cheese in forum Blu-ray RippingReplies: 8Last Post: 18th Nov 2008, 09:23
