I have successfully created a video on VCD and played it on my DVD player. I am using Pinnacle DV v8.
However I have tried to add another video to the same VCD. It will not pley - it plays the first one in a continual loop.
Is it possible to add further videos to an already burnt VCD?
Nope. It's not possible to add anything to an already burnt CD. But you could extract the MPG from the VCD with VCDGear, then either join this with some other MPG, or author your VCD with some app that allows you to add more than 1 mpeg stream, like VCDEasy.
/Mats -
Originally Posted by stevejordan
If you made a VCD with 2 mpegs, the disk would have 3 tracks, tracks 2 and 3 would have the mpegs.
So now that you have made the VCD you cannot add the 3 tracks, because the data track has already been written it it is that which contains all the information about the disk.
In order to be able to add the third track, you would need to have the disk as a multi session VCDEven though there is a good chance your PC could play it, there is not much chance a DVD would play it. AND you would have a heck of a time trying to get an authoring program to do it...
There is less chance if you closed the disk after you made the fist VCDWhich has to be done on VCD disks anyway
Disks are sooooooo cheap...... don't loose any sleep worrying that you have room on the CD...
Copy the .dat file back onto your hard drive and drop it into your authoring program along with the other mpeg you want on the disk. Most authoring programs will except the .dat as it is without the need to do anything with it.
Existing Video System Upgrades
By jasonaroth in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2011, 09:52 -
Creating New Chapters from Existing DVD
By matthewjohn23 in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2011, 03:14 -
Overlay still images on existing video, temporarily
By paros in forum EditingReplies: 11Last Post: 30th Aug 2007, 18:15 -
Replacing existing audio of a video
By aruwin in forum AudioReplies: 6Last Post: 10th Aug 2007, 18:54 -
Question regarding making an existing video larger
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2007, 09:15
