Results 1 to 9 of 9
  1. Hi, did anyone of you have experiences with the DRU-500A 1.0f and Verbatim DVD-R (94077) media. I have tried it with various programs (Nero 5.5.10.0, WinOnCD 6 DVD, RecordNOW, Instant Write) and I always get medium error and always at the same position.
    Error 00000200:08000000 writing block 000bb0f2 in Disc 01 Copy 01, Track 01
    BID: 0020cc60 BOD: 000bb0f2
    Command Aborted in Unknown device function at 0 (0)
    GRI_WriteBlocks
    #Track list#
    00: D0 T1 CD-ROM DM 00 SC 0 0020cc60 Datenprojekt, Dateien [KR_101_112] ISO 9660 / Joliet / UDF
    Did anyone have had good results with the 94077 DVD-R media from Verbatim ???
    thx
    mADmAX
  2. Is this the media noted in the pink insert that comes with the drive stating 2x DVD-R Verbatim media manufactured before Oct 31 2002 does not work?
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. I don't know. I have ordered this media in germany and I thought that the media mentioned by sony was not distributed in europe...
    mADmAX
    Oct 2002
    Florida
    I have had great sucsess w/ verbatim dvd+rw 2.4x and dvd+r 2.4x that they have in bulk at sams. I never tried it before the upgrade to 1.0f though.
  5. I have read your post. I live in Italy and I have a SONY DRX500UL, the external drive, it is EXACTLY the same as when connected with PC it is recognised as DRU500A....I have 1.0f firmware and I have tested some DVD-R.
    With VERBATIM I have the same problem, they DIE when about 13% of mastering.
    I have tried HAMLET but the machine simply doesn't recognise them, it says: BLEAH!
    I have used with success IMATION (Euro 3.50), TDK (Euro 12), MMORE (Euro 5).
    I use NERO 5.5.10.0 and Padus DiscJuggler 04.01.1056
    See you
    A.
    May 2001
    axlish: Where is your Sam's? Mine doesn't sell any DVD recordables. Do they have both DVD+R and DVD-R's?
  7. @artemio: Do your Verbatims also have the code 94077 ? Or do you have other Verbatim DVD-Rs ?
    I have also tested (without problems):
    Verbatim DVD-RW (43139)
    Verbatim DVD+R (43156)
    Philips DVD+R (DVDR/012)
    Philips DVD+RW (DVDRW/013)
    mADmAX
  8. Verbatim DVD-R is my favorite media to use with my Sony 500A. With this media, I can play on both of my standalone players Apex 1010W and RCA 5220. HP +r media will only work for my RCA and Princo media will only work for my Apex
  9. Originally Posted by mADmAX0001
    mADmAX
    Well, I think Italy is a leader between Third World Countries so I am sure that the VERBATIM DVD-Rs available here are those with code you mention. I haven't checked, sorry. I haven't tested other types like the + and - RW since I don't like very much them.
    See you
    A.
