  1. got really bad high motion bit noise.
    doing dvd to dvd-r using tmpg, tryed all encode methids, 2 pass cq the lot, source vob files ive checked and there isnt the same bit noise as when i encode it.
    tryed laods of settings, has any1 got any suggestions,
    src file = dvd vobs
    aspect = 4:3
    src aspect 16:9
    arrange mthod = ful lscreen keep aspect
    motion search on highest
  2. All I can say is 3 words...
    Cinema Craft Encoder!!!
    CCE is way faster and better than TMPG!
  3. can i open m2v files wid that tho ?
  4. You need to use DVD2AVI to create a .d2v file, and than create an AVS script to import in to CCE. There are some good guides at doom9.org
  5. whats the programe to make the script file,, il ltry it,, thanks
  6. You need the VFAPI Plug-In for dvd2avi
    and you need mpeg2dec.dll
    You create the avs file in wordpad
    EXAMPLE:
    LoadPlugin("D:\Programs\GORDIA~1\mpeg2dec.dll")
    mpeg2source("H:\test\test.d2v")
    ResampleAudio(44100)
    I recomend following the Doom9 CCE guides because there are some important settings.
    It's a little bit of a pain to set up, but you don't have to change settings everytime. It takes me about an hour and 15 minutes for a single pass on a 2 hour movie.
  7. i dont think its a tmpg problem,
    im sure its sumfing to do wid wich codec tmpg is using, i remember with all my good quality stuff, in the enviro options there was a ligos codec thing, now there seems to be a cyberlink 1?
    could this be the problem?
