Recently i downloaded a couple of divx avi files from the internet.When I opened the file it has no sound but the picture is at perfect quality.I figured maybe it was an error in that particullar file so i downloaded other divx avi files.
The same old problem occured again!Motion picture good but no sound!!All of my other freinds got 2 hear the sound from their own pcs but not me.
I currently have DivX Codec 4.11,'the playa' which comes with the divx codec,and wmp 7.1
can any1 help?
You probably lack the right audio codec. DivX is the video codec, so that's fine, but the audio is encoded according to some other method that it's likely that your computer doesn't have a decoder for.
Try the Nimo codec pack (if you run XP it's a good idea to make a restore point before...) and remove all spyware after install.
/Mats -
Don't install codec packs...Originally Posted by Laur3nce
test your system and find out what you have missing, then just install that.
http://www.vcdhelp.com/forum/userguides/135217.php
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 03:16 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 06:02 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21
