Is there such as thing as a DVCam AVI codec? I'm sure others have experienced the horribly choppy playback when playing freshly captured DVCam AVI files. Is there any way to fix this?
There's the DV codec. Whenever I use it, it plays fine. Perhaps your computer is underpowered?
I get the same problem using a DV camera and firewire. Have made sure to have the DMA on the HD enabled and a high speed HD (7200 rpm) but still get the same prob. Actually I get grainy or with moving lines through it like heat waves of sorts. Sometimes there are areas that appear to have "blocky" appearance.
Braindrain, what do you mean by DV codec? -
Yeah, I'm talking about playing back the captured video file via FireWire from a miniDV camcorder. The file type is .avi, and it is in 720x480 in an "Unknown format." Playing it through media player results in choppy video with audio out of sync. Trying to preview it through the properties tab sends up an error, "Cannot find vids:dvsd decompressor."
If a codec exists to play back these original captured files, then we're ok.
My PC isn't underpowered... pfft. Thunderbird 1.4ghz, WD 7200 rpm 45/27 gb drives, etc etc. It can play back anything you throw at it.
Sony DVCAM
By gash69 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2011, 10:36 -
DVCAM 4 channel audio
By logicom in forum Capturing and VCRReplies: 5Last Post: 2nd Dec 2010, 06:19 -
Noisy DVCAM Footage
By RABinMS in forum RestorationReplies: 6Last Post: 13th Jan 2010, 09:41 -
DVCam or DVCpro?!
By B-Twien Bytes in forum MediaReplies: 0Last Post: 18th Oct 2009, 08:32 -
480i/480p in DVcam vs. conversion
By celticwhisper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 19th Jun 2007, 12:54
