I have read that 3:2 pulldown is used for converting from 23.976 to 29.976 fps, or something like that. The part that confuses me is, can you use this for both interlaced and non-interlaced sources??? Or do each of them have a different fps???
My source is 23.976 fps, as it states in DVD2AVI, however I am confused as to whether I should choose interlaced or non-interlaced and whether or not to use 3:2 pulldown to get the best quality picture.
Please tell me which will result in best picture.
I think I found my answer, that my film source of 23.976 fps, is a non-interlaced source and that 3:2 pulldown should be used.
Is this correct??? -
maybe look at this site
www.100fps.com
it might help you a little
if nothing else it's an entertaining read -
The video tab lets you set the output for your encoded file, the top of the advanced tab is where you tell the encoder the properties of your source. If there were anything that outright conflicted than I'm sure TMPGenc would not allow you to set them as such.
As far as the 3:2 pulldown while playback option is concerned, it does not matter whether your source is interlaced or progressive. The simple rule is this, if you are encoding mpeg2 (SVCD or DVD) at 23.976fps then always include the 3:2 pulldown flag, and if your using TMPGEnc than that means always use the 3:2 pulldown while playback option. Do not confuse this with the 3:2 pulldown filter on the advanced tab, this is for performing a hard telecine which rarely will ever be needed.
If your source is non-interlaced then let TMPGenc know by setting this option in the advanced tab. Also set the aspect ratio of your source. From there you are free to use any output settings that aren't greyed out.
Encode in Interlaced or Deinterlaced w/Pulldown?
By CubDukat in forum Video ConversionReplies: 4Last Post: 19th Jun 2011, 18:29 -
Please, help to convert progressive source to interlaced result
By lovyagin in forum Video ConversionReplies: 11Last Post: 6th Oct 2009, 12:57 -
Interlaced source encoded as progressive?
By MagicSparky in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 18:30 -
Help with possible interlaced pal avi source
By h2p000 in forum Video ConversionReplies: 4Last Post: 28th Feb 2008, 18:41 -
How to deal with 23.97 interlaced source
By mpiper in forum Authoring (DVD)Replies: 18Last Post: 15th Dec 2007, 23:45
