Searched around a bit for the answer, but didn't find one:
What I can't figure out is how to get virtual dub to see the tv channel I want to capture from....
I opened my ATI tv program, set the channel, closed it, but Vdub still plays the same channel as always... any ideas?
thanks
Maybe in the capture window of VDub you'll find "Video Source". There you can chosse "TV" and wiht "properties" you can select the channel.
Translated from german so your english version might be different. -
Yes, this is the way you select the channel you want. Although you have to do this every time you start vdub, there is no way that I can see to save the last channel entered.
Using a monophonic VCR for playback - disconnect right channel for capture?
By justin81 in forum Capturing and VCRReplies: 3Last Post: 13th May 2010, 11:55 -
I Need a multi channel capture device, what should I buy
By flyrplnz in forum Capturing and VCRReplies: 0Last Post: 3rd Mar 2010, 21:39 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
any way to capture 2 channel audio when VCR only has white plug?
By cduval04 in forum Capturing and VCRReplies: 6Last Post: 20th Jan 2008, 15:55
