When I drag/drop the .avs file into CCE, it says "OpenMovieFile() file
(-2095)" .. Backing up "Attack of the Clones" via:
SmRipper
CCE
IFOedit
(also using DVD2AVI, Bitrate Viewer, AVIsynth)
I'm ready to just buy the damned movies... This sh#@ is frustrating! Any help w/b greatly appreciated. Thx.
It's impossible to know what the problem is with an AVS file if you don't post the script. I'm guessing your syntax is just off somewhere.
Second, do not drag and drop any kind of file into CCE. This has been known to cause problems. Instead right click on the white box, select add, then load your avs/avi/vdr file. Just a little tip, I don't think this actually has anything to do with your problem.
You should buy the movie. This forum is intended to help people with backing up their dvds, among other things, not with illegally copying dvds. -
<sigh>
http://www.avisynth.org/index.php?page=Section+2%3A+AviSynth+and+frameserving#q20
The script is irrelevant, AVISynth is not producing the error.It's impossible to know what the problem is with an AVS file if you don't post the script. I'm guessing your syntax is just off somewhere. -
OK, thanks but.. I just installed trial version of CCE 2.66 (was using 2.64) and the message I'm getting now is "Frame size 924x56 is not supported. Frame sizes up to 720x576." I'm clueless what that means..
I checked my syntax in the .avs files like 5x and I'm fairly sure I've got it right..
LoadPlugin("C:\unzipped\video tools\AviSynth2\Plugins\MPEGdecoder.dll")
mpeg2source("C:ATTACK CLONES-SmRip\ATTACK_OF_THE_CLONES_D1\\clones.d2v",iDCT=2, CPU=0)
I'd try CCE2.5 but I can't seem to dl it from doom9.org ... Thx again. -
oddbod77, have you actually ever used avisynth?Originally Posted by oddbod77
Of course the script is relevant, when frameserving via avisynth you must properly load the source in your AVS script otherwise the encoder/decoder will not be able to read it and will return an error. There are a plethora of similar errors that can be invoked in CCE simply by changing one character in your AVS script.
If there were something wrong with your script and you loaded it into CCE than how else would you know unless CCE returned an error. Its not like avisynth is going to give you an error msg. (unless you try to play the file.)
There are many possible reasons why CCE is returning the error, the script could be wrong, avisynth may be installed incorrectly, he may need to use an avi wrapper. Generally when there is a problem loading an AVS script its because of a problem with one of its commands. The first step in problem solving this is to actually see the text of the AVS script.
Officexp 2002 won't accept my serial to put back MS Word
By abrogard in forum ComputerReplies: 10Last Post: 21st Oct 2008, 01:09 -
Vegas 6.0 Won't Accept mov file
By solarblast in forum Video ConversionReplies: 18Last Post: 18th Oct 2008, 11:17 -
Imac won't accept blank DVD-R DL with Toast????
By dunpal in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 18:04 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 15:57 -
Help with avs script to cce 2.7 for sports program
By JasonCable in forum Video ConversionReplies: 3Last Post: 1st May 2008, 09:03
