I'm trying to join 2 mpeg files in TMPGEnc 2.59. I'm using the Mpeg-1 VideoCD template in Merge and Cut. I keep getting the following error, "File mr-pt.2.mpg is not compatiable with the other MPEG file." I cut the file with Merge and Cut in TMPGEnc. Its a 3 hour movie in 2 files, so it need to be 3 files. Is there is a better program instead of TMPGEnc to join mpeg's? Can someone help me with this?
Results 1 to 11 of 11
Hey Poppy56
Are your Mpegs both the same resolution, video bitrate, audio bitrate, same resolution? If so, they should work. If not, you're going to have to re-encode one of them to match the other.
chas -
Chas,
I don't know if both of the files the same bitrate and resolution. How do I check to find out?
Thanks for the help. -
Poppy; you can check the files with 'Bitrate Viewer' which can be found with Google search. It's freeware and will tell you all about your MPEG files. If they're MPEG1 files then Virtual Dub will tell you under file, info.
chas -
Chas,
I checked the resolution and bitrate. The second mpeg I'm trying to merge has a different bitrate and resolution than the first. They are not the same. How do I change the bitrate and resolution in TMPGEnc to re-encode it?
Thanks -
Poppy,
What are the bitrates, resolutions of each Mmpeg, and are they both Mpeg1 or Mpeg2 files? Which file is the largest and are you making a VCD or SVCD. If you answer all 5 questions I can help you.
Chas -
Chas,
The 2 files are MPeg1 and I was making a VCD.
The bitrate and resolution:
File1 - 1150Kbps, 640x272, 23.976 fps
File2 - 1149Kbps, 640x272, 30.000 fps
Thanks -
Can someone tell me how to change the bitrate and resolution of a mpeg file?
Thanks -
Originally Posted by poppy56"Knowledge makes a man unfit to be a slave."
Frederick Douglass
MPEG Streamclip to join files but not transcode?
By Corbey in forum Video ConversionReplies: 2Last Post: 12th Apr 2013, 12:18 -
How can I join MPEG-2 files?
By sofakng in forum EditingReplies: 6Last Post: 30th Jul 2010, 10:20 -
TMPGEnc 4.0 XPress- Join video losslessly
By ranosb in forum Video ConversionReplies: 2Last Post: 30th Aug 2009, 13:00 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 01:18 -
can't join simillar mpeg-1 files without re-encoding
By sohaibrazzaq in forum EditingReplies: 3Last Post: 26th Jan 2008, 08:09
