The drop down menu only lists "No CD Writer Selected" and the CD/DVD Reader in the Laptop - it does not recognize the USB Burner. Any ideas?
I have rebooted with the Mitsumi USB burner till the cows came home with no luck. Please advise.
I'm not sure about USB burners, but the general fix is:
Open VCDEasy, in the bottom right corner, does it say ASPI seems valid: yes, or ASPI seems valid: no? If it says ASPI seems valid: no, that is your main problem. In that case I suggest you go to: <http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm> , download the ForceASPI drivers, install them and reboot. If after you reboot, it shows "ASPI seems valid: yes" then on the CDRDAO settings page, select generic-mmc as the force driver for the CD Writer, select your specific CD Writer in the dropdown menu for that section and check the force execution box. Now you should be able to burn using CDRDAO, which is the CD burning program built in to VCDEasy.
If it still doesn't burn then the second thing to check is VCDEasy set to "Simulate Burn" that is right on the main page. Uncheck "simulate" and check "burn".
If the above steps don't work, the problem may be something specific to USB burners.
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
