I know this is a newbie question, but I have always been a fan of VCDs, and now I am planning to venture into the mysterious world of SVCDs but am not sure if it is worth it. Is the quality of an SVCD better enough than the quality of a VCD to switch over and lose the amount of possible time that can be stored on one disc? In FFMPEGX, is there a great difference in encoding times? I am currently planning to use DV footage and convert it into SVCD through FFMPEGX v0.0.5.
Thanks,
Wolfwood87
Results 1 to 11 of 11
SVCD is better but you're not going to notice any significant quality gain if using the same bit rate (eg 1150 kbit MPEG-1 vs 1150 kbit MPEG-2). You can decrease the bitrate from 2500 to squeeze a movie on two CDs. You may also be interested in making CVDs. I made a CVD from Office Space yesterday and the whole movie fit on one CD! Looks pretty good.
It was kind of a fluke; getting it onto one CD that is. The total time for Office Space is about 90 minutes. I used the CVD preset for in ffmpegX and kept the bit rate at 2300. I changed the audio bit rate to 128 and the sampling to 44100 hz (48000 on VCD/SVCD sounds strange on my player). Under options I only have Altivec and QT decode checked. Thread is also set to dual CPU (cause I have one). Constant bit rate is also checked. Deselected author as SVCD under tools because I used MMB. Keep elem streams, echo command line, author as SVCD, and postprocess were checked as well.
It took a few hours to encode on a Dual 867 MDD (although I was doing other stuff while encoding). The end file ended up being about 739 MB so I had to overburn w/MMB. You can shave some time off the movie by not encoding the credits.
Hey umm what is a cvd i mean i am not really a newbie but i have never made a cvd so if you can tell me the bitrates and the resolution and all the details. and you said you fit Office Space in one cd what im wondering is how long did the movie last and what bitrate did you use. if the movie was around 80 minutes then you would have had to use bitrates like vcd right 1,394 or if not tell me i wanna know what a cvd is. plz.Originally Posted by SCBCecilio
> Which gives a better overall quality: CVD or SVCD?
Depends on source material... I noticed that with high motion movies CVD is better than a SVCD with the same bitrate (I think 'cause it needs less bits due to the resolution: 352x576 vs 480x576 - I work in Pal!). But with low motion movies SVCD gives you a clear and more defined image...
In any case the difference is very little!
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
Bad quality WMV - will a conversion increase quality?
By nickbrace in forum Video ConversionReplies: 4Last Post: 20th Oct 2011, 05:48 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
