Who has an excellent Tmpgenc template for squeezing a 144min ( ??? ) movie onto 2x80min cds in xvcd 352x240 format.
All the templates I have tried ( including kvcd) seem to give me bigger than expected files. Even my attempts to alter the vbr to low 500kbs give me the same size file as a 1500kbs vbr UNLESS I choose to make the system (last tab in tmpg settings) a Mpeg-1 system instead of a Mpeg-1 nonstandard video-cd. The resulting 500kbs vbr file is actually not that bad apart from some parts ( more colour more action -ie. swimming pool) that are extremely blocky.
Results 1 to 10 of 10
This is what a 138 minute movie (K-19) looks like on ONE CD-R at 528x480. Imagine what it will look like if you target with file prediction for two CDsOriginally Posted by pyst
http://www.kvcd.net/k-19.cq.65.5.high-quality.matrix.BETA-1.dither.5.mpg
Read about file size prediction here, and at 352x240, you can put "Minority Report" on one CD and it will look just like a standard VCD. Read here: http://www.kvcd.net/forum/viewtopic.php?t=2102
Or pick up a HUGE mug of coffe and read this whole section
: http://www.kvcd.net/forum/viewforum.php?f=27
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
I think your problem is TMPGEng 2.5.9 wich just can't mux XVCD. Try an older version and your template should work.
I did that movie in two CD's last week using a CVD template and it looks excellent, of course the movie is 16:9 aspect ratio ant that helps alot.
I just loaded the standard SVCD film template, changed the resolution to 352x480, two pass VBR, average 1270 kbps with 300kbps as minimum and 2560 as maximum, and soften block noise enabled. after the encoded finished I remuxed using SVCD VBR as the stream type. and I ended with two 798 Mb files that play in my Apex 1100W DVD player once I burn them using nero non-compliant SVCD option. -
I wonder if my only problem was thinking I had to be able to make my mpg in the VCD-non standard format rather then just using the Mpeg1 system ( automatic or variable ) format. I'm not sure what the purpose of the non-standard vcd setting is.
Kwag,
Your clip does look good and gave me cause to try your templates a bit more but I found that the enhancement seemed to have more to do with the dimensions of the mpeg they produce than anything else. At least that is my opinion. I tried using one of your 352x480 improved templates with more normal 352x240 dimensions and got a result similar to anything else of the same filesize.
filerabe,
I tried an older version but the same thing happened but then my first statement in this reply might be my answer.
penamty,
Well that seemed to work with a reasonable sized resulting file but if it's vcd,svcd,xvcd or even dvd( maybe) ANY of them made into the same size file seem to look the same to me - my eyesight probably needs checking. -
It WAY more that the dimensionsOriginally Posted by pyst
At 352x240 you can now get ~180 minutes ~VCD quality if source is 16:9 FILM 24fps or PAL 25fps on one CD-R with the same techniques
hi kwag,
It doesn't help that your website is confusing to me and your answers are not specific enough.
My movie is NTSC 4:3 ratio. Minority Report - 144mins.
Which template EXACTLY should I use for one cd.
Which template EXACTLY should I use for two cds.
I just used a kcvdx3 template and got a good result BUT double the file size I need. -
For that specific movie on just one CD, use the KVCD LBR. And that's going to be tight because it's a full screen movie. If it was the wide screen version, your result would be much better.Originally Posted by pyst
For two CDs, use the KVCDx3. That will look REALLY nice on two CDs
In both cases, use file prediction.
Well, I'm off to see the optician because I'm damned if I can see much difference about anything.
Maybe I need to see a sample of a more animated and more brightly lit film sequence in a 4:3 formatted film to be convinced because I think the K-19 segment you use is a perfect piece for showing off mpg conversions at their best and not a good TEST of your template.
A comparison between a test mpg made with your gop setting and another with the default setting showed no difference that I could see. I'll have to go and dig out a 16:9 movie with dark little animated segments to see if I have more success. -
Maybe this
http://www.kvcd.net/matrix.cq.beta1mat.sample.m1v ???
Explanation of how it was done is way down this thread: http://www.kvcd.net/forum/viewtopic.php?p=12499&highlight=#12499KVCD.Net - Advanced Video Conversion
http://www.kvcd.net
This Virtualdub crash report mean anything to anyone?
By brassplyer in forum EditingReplies: 4Last Post: 30th Jan 2011, 20:35 -
Report: Windows 7 to Launch on Oct. 23
By Soopafresh in forum ComputerReplies: 7Last Post: 2nd May 2009, 23:27 -
How do I report a bug in SUPER?
By rafwuk in forum Newbie / General discussionsReplies: 2Last Post: 9th Apr 2009, 10:39 -
Eclipse report says 0 errors or warnings. . .
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2008, 14:48 -
Should movie studios report ticket sales instead of money totals?
By yoda313 in forum PollsReplies: 25Last Post: 18th Aug 2007, 11:53
