ok, is the divx codec the only codec that you can use "9999" to make it automaticly insert the keyframes? and if so what is the best number to use for where to insert a key frame?
any suggestions.
is anybody reading this? does any body have an answer? help me out.
Virtualdub will put in keyframes whatever the compression. Open virtualdub, go to file - open video file, tick the box stating popup extended open options, select avi file to open, press open, in next box tick off rederive keyframe flags, click on ok. Virtualdub will put in new keyframes as it opens file. Now save avi with new filename, but with direct stream copy selected for both sound and video. New avi has all the new keyframes without recompressing
Split video outside the key frames?
By KeyMs92 in forum EditingReplies: 14Last Post: 23rd Sep 2011, 07:53 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
VDub, Key frames and syncing...
By takearushfan in forum Newbie / General discussionsReplies: 4Last Post: 16th Feb 2010, 15:04 -
Change the key of a song to another key?
By Ikka in forum AudioReplies: 4Last Post: 3rd Feb 2008, 14:27 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
