Results 1 to 9 of 9
  1. i'm trying to get dvd2dvdr to work but after it rips i get an error message when "7:59:54 PM searching for DVD2AVI and Plugin... FAILURE" but i have dvd2avi installed all over the computer including in the dvd2dvdr folder. also can people go over how they installed dvd2dvdr because it was really screwy and i might have done something wrong. where did you extract all the files.? thanks
    True Story
  2. did you click on the big button with the pc on during installation, because it looks like you have manually extracted which is why it isn't working
    Jan 2003
    Germany
    Hi.
    I had the same problem.
    search in google for "cinema craft 2.50" and install it.
    It worked.
    Only version 2.50, all other didn't work on my pc
    Edited by Craig Tucker
    Chris
  4. thanks guys...i did manually extract it....i guess i wasn't suppose to....i'll try without manually extracting
    True Story
  5. Originally Posted by Polly_31
    Hi.
    It worked.
    Chris
    Did you read the forum rules before you posted.
    Do NOT give warez.
    Do NOT link to warez .
    Do NOT ask for warez.
    Do NOT provide information how to obtain warez.
    Do NOT advocate warez.
    Further posts advocating warez will get you banned from the forums.
  6. I've the same problem,
    Will loading the .ecl file, get ride of customization needed on CCE, and
    Will the final m2v (After PullDown) file size be sutiable to fit on 4.37 DVD-Rom?
  7. The moderator reaction is really a no-sence, because Cinema Craft Encoder is part of DVD2DVDR software and Polly_31 never said he used a crack or sthg. He just said he dowloaded the software after looking in google (not a link!)
    It's all about hypocrisy; this whole site is about unlegal stuff in fact !!!
    Bruno, 30
    Brussels, Belgium
  8. maybe you should have read the bottom of Proly_31's message, brunitou.
    it says "Edited By Craig Tucker". which looks to me like there was something there that should not have been written. NO, cinima craft encoder is not a part of the dvd2dvdr software.. it is a seperate piece of software that can be used if you want to encode your movie. and it is not illegal to make A copy of a movie that you already have, for your own personal use.
  9. Originally Posted by brunitou
    If you look at polly_31's post you will see that I edited it to remove information on how to obtain a crack, which is against forum rules.
    If you don't like it, go and use another forum which allows the distribution and promotion of warez.
    Members of this forum are asked to obide by the forum rules, those that don't will have their posts either edited, locked or closed, and if they continue to flout the rules may find that they eventually get banned.
    As polly_31 is a new member I am sure that this was just an oversite. It is my job to point these oversites out to new members so that they know for future posts.
    And this whole site is not about unlegal stuff, as you put it. VCDhelp does not condone any illegal activity. It provides information and support on how to make fair use backups of your media
