I made an illustrated guide for making SVCDs. Hope it helps everyone out who is still having problems. Here's the link:
http://users3.ev1.net/~jacobsag/vcd/svcd_guide.html
Results 1 to 10 of 10
I haven't tried to make an SVCD from X-Men with this method. Before the QT Decode option was available I tried converting it to VCD with ffmpegX. It stayed perfectly in sync until about 47 minutes or so into the movie - the part when Rogue is sucking the energy from Wolverine. After this point the video just froze up. I also tried converting to DivX and the video didn't freeze but it still went out of sync at the same point. Framerate change? Is this what happens when you try?
Yeah, that sounds very similar to what I'm experiencing. I've honestly tried about 10 different ways of converting it to SVCD, but no luck. This is the only DVD I've run across where nothing worked, not even Bilestyle's old method of converting the vob to DV first. I also tried just ripping and converting a few chapters, but problems there too.
I noticed before 1/2 way through (probably around your 47 minute mark), no matter what method I use the video starts stuttering a bit, and eventually sync gets off and stays that way. The new ffmpegx refuses to convert the whole thing as well, it's strange. There's definitely something weird going on with this one.
There are ways to get subtitles into the movie but not with this method (not that I know of). If the subtitles are hard coded into the movie (Rush Hour), then there's nothing extra you need to do to encode them. However, if they are not (Star Wars Ep. 2), then you are SOL. Bilestyle and Kaicherry are working on an easy way to include subs. I think Mpeg2DecX is supposed to work for subtitles but I've never tried it.
searching for a guide....
By videoman3344 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 04:13 -
Numpty's Guide Please
By Dan Dare in forum Media Center PC / MediaCentersReplies: 7Last Post: 10th Dec 2008, 02:55 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 21:42 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 23:34
