I already read some guides but sill I have some questions Iam using FitCd
and my script look like this:
# -= AviSynth script by FitCD v1.1.2 =-
#LoadPlugin("D:\PathOf\AnyPlugin.dll")
AviSource("F:\Red Dragon\test.avi")
BicubicResize(480,288,0,0.6,10,0,620,272)
AddBorders(0,96,0,96)
#Trim(0,3646).FadeOut(150)
I tried to resize and my first question is what is crop good for and what b and c parameters are??
The second thing is I tried to resize my NTSC file(640*272) to 480*360 but it seems to be impossible cause when I resize to 480*288 or 480*304 my destination in FitCd is always 480*480 so what is the difference between this two resolutions and how can I resize to 480*360??
And is it a quality difference if I use FitCd or write my own script something like this:
LoadPlugin("c:\mpeg2dec.dll")
BicubicResize(480,360)
Sorry I know lot of questions but I would appreciate your support
Thanks!!
Results 1 to 15 of 15
I basically have the same question ocelot.
Can you list all the tools and instructions you used up to point where you are? Thanks! -
Well I use CCE 2.66, FitCd and Avisynth 2.05 dll. Read this thread http://www.vcdhelp.com/forum/viewtopic.php?t=112705
Originally Posted by ocelot
this is the only valid SVCD resolution. what you can do is addborders to make the resolution correct. Use second script you posted, but with one addition:
addborders(0,60,0,60)
http://www.avisynth.org/index.php?page=Resize
--this should answer your question about b and c valueswhat are you askin' me for...
I'm an idiot! -
AHHHHH
some things seems to be clear now Thanks!!!
But still I dont know what cropping is for. Is it only necessary if you want to make your movie resolution smaller for example 480*480 to 320*120?? -
Cropping is primarily used to cut off the captured letterboxed black borders so that they can be replaced with PERFECT black borders, in increments of 16. Also to cut off the overscan area and any edge errors usually associated with VCR playback.
BTW, on your resize, I would NEVER resize upward, just add bigger borders. -
Originally Posted by Nelson37
I've resized upwards w/bicubic, and have gotten excellent results.
I prefer that to having the borders take up half the screenwhat are you askin' me for...
I'm an idiot! -
This will probably be of interest to many of you
http://www.kvcd.net/forum/viewtopic.php?t=2259
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
Originally Posted by kwag
You kvcd guys have really good ideas sometimes.
BTW, thanks for excessive prediction script testing. -
Originally Posted by Truman
As SansGrip said the other day: "Things are pretty chaotic right now"
That's all the stuff going on at KVCD.Net. Too much development and people are lost. Eventually we'll get things organized, and the big picture will be clear 8)
Is this a right script for removeborders??
#LoadPlugin("c:\mpeg2dec.dlll")
#LoadPlugin(C:\removeborders.dll)
AviSource("F:\test\test.avi")
Removeborders()
BicubicResize(480,384,0,0.6,8,0,624,304)
#Trim(0,2036).FadeOut(150)
If yes it doesnt work for me. -
RemoveBorders() is not yet finished. It only does that. Removes the borders. So far, it seems to be accurate, so just keep an eye on that thread for future development
Ok thanks!!
And why is it necessary to give the last two values in the bicubic parameters??-> Bicubicresizer(..,..,..,..,..,..,670,352)
I think its the source value but is it necessary the write them??
Thanks!! -
I feel, now it is time to RTFM
BicubicResize(NewFrameWidth,NewFrameHeight[,b,c],CropSourceLeft,
\ CropSourceTop,SourceFrameWidth,SourceFrameHeight)
BicubicResize(320,160,1/3,1/3,10,10,630,424)
is the same as
Crop(10,10,630,424)
BicubicResize(320,160,1/3,1/3)
New AVISynth UI
By tin2tin in forum Latest Video NewsReplies: 23Last Post: 19th Jan 2012, 01:53 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 04:36 -
Using avisynth
By bsuska in forum Video ConversionReplies: 8Last Post: 16th Jul 2009, 08:32 -
AVIsynth help!
By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 03:35 -
Avisynth 3.0
By nbi in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:50
