Ok guys .. trying to figure out the best settings to re-encode this sucker using DVD2SVCD .. but its giving Dvd2avi fits !
Every other frame it switches back and forth between "progressive" and "interlaced" i have never ever seen a film do this ?? Which is it ?
Getting about 1/3 through the movie the film is up to 80% film .. this isn't enough to use "forced film" correct ?
What is the aspect ratio of this film ? DVD2AVI shows 4:3 with letterbox .. can i re-encode this with DVD2SVCD's "16:9 Anamorphic" setting and maintain the picture ? Or should i re-encode with 4:3 ?
Any help is appreciated !
i used dvd2svd awhile ago with this movie and i just set all the settings to default and it woked great. if dvd2avi keeps going back and forth then it is probably interlaced. dvd2svcd will pick up on it and encode it the right way. at least it did for me.
titanic is both interlaced and progressive ... and there is an error in the encoding at one part also ..
as stated, dvd2svcd should still do ok with it ...
strange dvd size
By pcb in forum Newbie / General discussionsReplies: 12Last Post: 7th Jun 2010, 15:38 -
Strange DVD/cannot import into Nerovision
By sonicdeth in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2009, 18:57 -
strange DVD problems
By mikehende in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2009, 17:43 -
Strange flicker on my DVD-Rs
By ministry88 in forum DVD & Blu-ray RecordersReplies: 17Last Post: 6th Mar 2009, 23:43 -
Very Strange DVD/VCR Problem
By powerhouse45 in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2008, 07:41
