  1. I have tried to burn a VCD2.0 and SVCD with JPEG photos. When I play the VCD in my Philips763 DVD player, some blocks of one photo are mixed with some blocks of the previous photo.
    I've tried with Nero and VCDEasy, and both give the same result.
    The same VCD seem to work well on a Sony DVD310.
    Did anybody had the same problem ?
  2. You have to use to burn yr svcd with Ulead DVD Movie Factory
    This will solve yr problem.
  3. Actually the same thing happened to me with a VCD with hi-res JPEGs on a Phillips 724. I found out that if I advanced one image and cam back to the image with problems then it would display it ok. It also seemed to me that if I waited a while between changing images it would usually display them correctly. My VCD was burnt on a FujiFilm CD-RW, perhaps this has something to do with with the medium?
