i know that Scenarist support but its to hard to learn it....is there a guide on the net for Scenarist?
Results 1 to 11 of 11
there is one on doom9 but i'm sure your dealer will be happy to instruct you a bit (well most dealers - i know of at least one that will not) on how to use it, since its a $20,000 program ... and it comes with a manual also ..
sonic also has support ... -
SpruceUp is not Scenarist ... totally different programs ......
but yes - they both support ac3 -
i just tried to import AC3 data to SpruceUp and he reject it...
am i doing wrong?
i am going to the movies TAB to import ac3 data but i cant!
when you said SpruceUp support ac3 data you ment when the ac3 data is attched to the mpeg? -
well I tried Spruceup and it errored out my ac3 also and I tried to import a VOB with ac3 and it errored out also. does anyone know if DVDit or ReelDVD supports VOB's with ac3. I have both and wanted to know before installing the programs.
Originally Posted by thxkid
Just make sure both files are named the same; eg. movie.m2v and movie.ac3. Then open Spruce and import asset movie.m2v and it will automatically bring in the ac3 file (why it's important for the names to be the same) -
The only ac3 i can get sruce up to take is 2ch, not 5.1
DVD Authoring for MKV files and dts, ac3 support
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2011, 16:32 -
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 19:03 -
Convert HD MKV or AVCHD to HD MPEG2/AC3, with subtitle support?
By elsinga in forum Video ConversionReplies: 14Last Post: 25th Dec 2010, 13:56 -
Roxio DE 6 does not support AC3...what are my choices?
By utlax18 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2008, 14:43 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
