I have recently downloaded a couple of xvid avi's which when i play in wmplayer or try to convert using TMPGEnc it comes out green. I have conerted Xvids before and I have the codec according vDub and GSpot.
Can any one help?
I don't whether it has anything to do with upgrading to wmplayer 9 which I did a few weeks ago.
If you have the Nimo Pack UNINSTALL it! For some reason when it installs it screws up the xvid codec. Then grab the xvid codec and install it again... I had the same problem and this fixed it
Thanks for that
I tried this but i still have the problem. But when I uninstalled nimo, the xvid avi's still played in the same way. I installed a xvid codec on its own but th problem is still there -
i had the same problem, and i found the solution. al least for me.
uninstall ALL codecs.
then install the xvid codec,
then install divx4.12 codec
then install nimo but uncheck all codecs, and uncheck directshow
and check ac3 sound.
now you have sound and a good picture.
follow the steps otherwise it won't work
enjoy. -
I tried this but still the same problem
I don't understand why vdub is fine with the xvid files but wmplayer and tmpgenc have a problem.
can anyone help?
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 11:48 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 19:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 16:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
