I have been using TMPEG for a few days with great sucess converting my AVI to a single 80 min disk size. Except I have one AVI divx item that TMPEG is showing the wrong length for. I have tried to convert and ignore the warnings, that it will not fit on one CD, but it errors out as soon as it starts to convert. And if I do use the length of time as it states to set the average bit rate the video looks horrable. Any one experiance this problem?
You could try opening the video in VirtualDub, setting both Audio and Video to Direct Stream Copy and saving it to AVI again.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
Ravenrose,
take a look at this: http://www.vcdhelp.com/forum/viewtopic.php?t=135200
I think I had the same trouble and solved it with their help! -
Hi,like it says in the link provided by der_mac,if you save the wav in virtual dub it corrects the time in Tmpge ,had this problem months ago and this fixed it,
Avi showing wrong length. Encoded with virtualdub
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 3rd Nov 2011, 12:06 -
Player showing wrong length even though all video is present
By Xqwzt in forum EditingReplies: 4Last Post: 15th Oct 2011, 13:40 -
.ASS subtitle is in sync but showing at the wrong position
By onlinepen in forum SubtitleReplies: 2Last Post: 9th Nov 2009, 04:48 -
wrong movie length, audio delay
By KlintIstwood in forum Blu-ray RippingReplies: 6Last Post: 23rd Mar 2009, 14:10 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 19:34
