I capture my video to MPEG 2 using Ulead Video Studio 4.0. Then I encode it to SVCD and burn it. When there is alot of movement the picture gets blocky. How can I fix this??
I have;
AMD T-Bird 900
128 Ram
30 gig 7200 RPM HD
Win 2k
AIW Radeon 32 mb
Please Reply,
Thank You,
Eric
I know what the problem is>>>Stupid Software!!! It is nothing but junkyass Ulead Trash! .
I use campeg program that works really well! -
Have you tried any of the following?:
Increasing the bitrate during capture or capture to a low-compressed AVI (Huffyuv or MJPEG) instead of MPEG-2, using the Soften block noise option of TMPGEnc, using High or Highest quality motion search in TMPGEnc, running some noise reduction filters on the video, or trying to make a non-standard SVCD with a higher bitrate.
-Cart
http://www.geocities.com/lukesvideo/index.html -
Try doing a real time capture with your MMC 7.1 software that came with your Radeon. Do it just for grins. See how it compares to your Ulead captures.
Ntserver:
Where can i get the Campeg software??
Cart:
If I fun too many filters with TMPG the encoding will take forever. Given my machine specs how long do you think it should take to encode my mpeg 2 to SVCD using the filters you suggested?
Thank You!!
Please Reply
Eric -
it's very difficult to get rid of all blockiness in high-motion scenes without really smoothing them over and stay within the VCD or SVCD specs. basically, MPEG compression works by using a whole picture (I frame) and then for the next several frames only coding the differences from that whole picture. so in high motion, there's lots of differences, and few bits to go around, so they all get coded but not very accurately. however, smoothing helps by blurring the edges and making the differences from frame to frame less significant.
capturing in real time will always look worse than a good offline encoder since there is no time constraint on the latter. but when you capture realtime MPEG-2 as an SVCD source to re-encode, use a very high bitrate (like 5-10 Mbps/5000-10000 kbps) and/or I-Frame only to get very good quality, because when you re-encode you lose some. -
Eric,
The amout of time it will take depends on the specific filters and settings you use. Personally, I like to use VirtualDub with the Temporal Smoother and Smart Smoother filters for noise reduction. In general, noise reduction filters are pretty slow. Like most things in life, the more time you put it, the better quality you can get out. If you test a shorter segment of your video, you can play with the settings and get an estimate of how long it will take to complete the whole video.
-Cart
Netflix prices going up again, a lot this time
By jagabo in forum Latest Video NewsReplies: 102Last Post: 18th May 2012, 18:00 -
I know you guys have answered this a lot, but on Burners
By tcory in forum Blu-ray RippingReplies: 3Last Post: 23rd Jan 2011, 20:39 -
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 15:06 -
Convert a lot of DV in to MP4 at onece
By Heinh in forum Video ConversionReplies: 0Last Post: 5th Jan 2009, 17:04 -
QT DV blocky playback
By Fifou in forum Video ConversionReplies: 5Last Post: 7th Aug 2007, 10:56
