I recently ripped a dvd on to 3 cdr-s, which i thought was silly although it worked, but my question is related to DVDX2.0 in the output setting if i chose to encode my DVD to SVCD and in the 'VOLUME DON'T EXCEED' menu i chose to VCD 80 mins, will my movie be encoded in SVCD 80mins per CD-R, or will it be VCD??
thnx
kas187...![]()
If you choose your output to be svcd it will be svcd. Keep in mind that because you are encoding an svcd, you will get less than 80 minutes of film on your disk. This is because your file size will be larger than that of a vcd since you are using a higher bitrate. A higher bitrate will make the file look longer in minutes than it really is. :P
ok thnx, do you have any idea approximatley how many mins it might encode, providing i keep most of my settings the same except for the resoulution
480 *576
and medium 4/3 letterbox vew
i wouldnt want it to be below than 70 mins, would that be suffecient,
thanx 4 ur help so far
kas187... -
It would be impossible to say how large your file size would be without using a bitrate calculator. Fortunately you can download one from the tools section of this webpage. On the left hand side of this screen click on the tools link. The very first selection on the tools page are bit rate calulators to help you decide what bitrate to use to fit your film on a cd. I've never used any of them, so I can't recommend one. Maybe someone else in the forum can.
When you change the "bitrate" in DVDX it tells you what the MB size is of the ripped movie will be.
I divide the size of my blanks into this figure, and set that figure in the output
sections disc size.
ie: if the total( depending on bitrate) and the ripped size is 2600 MB, I use three 90 minute CD-R's. ( You can adjust the bitrate up to fill the last CD-R. )
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
Having trouble using DVDx to rip to .mpg or .avi
By waldothewonderboy in forum DVD RippingReplies: 19Last Post: 30th Aug 2010, 03:48 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
