Okay, I've spent some time here going through all the guides. I really appreciate all the time and effort people give to this community.
However, while this may be a stupid question, I'm going to ask it anyway.
I have a .AVI capture and I'm trying to convert to MPEG so that I can edit it in ULEAD Movie Factory. I followed the guides, but TMPGEnc only splits the the file into and m2v and wav files (I actually edited the sound into another .wav file that I intended on using). Because Movie Factory does not understand the .m2v extension, how do I get to use the converted file? Do I simply rename it to .mpg? Then I can add the separate .wav file later, right? Please help. Thanks.
i don't use ulead products but generally you wouldn't encode to mpeg first - THEN - edit your video ... as then you would need to re-encode ..
you would edit your avi and wav in your video editor , then encode as the final step .. -
Thanks for your input. You are absolutely correct on that. I never looked at it that way.
For those who use Ulead products, once I am finished editing the .avi, then I re-encode, does WorkShop recognize the .m2v and will it burn it with the separate .wav file? Thanks again.
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 15:46 -
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 18:56 -
How to mux a m2v file with 44.1khz, 16-bit wav?
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 23:25 -
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 10:21 -
Authoring m2v,wav and idx/sub
By Soixante in forum Authoring (DVD)Replies: 5Last Post: 12th Feb 2008, 10:26
