Hi, just wondering if n e 1 could give me a little advice ? When backing up my dvd's, i can back up the dual layers through dvd2svcd, all work fine on ps2, using branded FWS 1x write dvdr's, with the Pioneer A04, when i back up a single layer dvd using smartripper, i can not get the back up to work on the ps2, using same dvdr's, will play on all 3 other standalone players which i have, have also converted vcd's and svcd's to dvd-r and they work perfect on ps2, with same branded dvdr's - FWS 1x write, Y won't the single layer dvdr's i have backed up work ?? They r the easiest to back up but i seem to get more of a problem getting them to work on the ps2.
Many Thanx
Max
just a thought!
why dont you use smartripper to demux to a m2v and ac3 then author with your authoring program like you would a dvd9 without the re-encoding, instead of a backup.
maybe the ps2 is funny about complete backups.
worth a go!
thingimijig. -
Try using DVD Decypter to read it as an .ISO then write
Use Mode, Iso, Read
Then Mode, Iso, Write -
ok, wat version of dvd decryptor do i need ?? i have ver 3.0.0.8 but there is no option for iso that i can see.
Many Thanx
Max -
I'm not sure when it was implemented but the last few versions have had it under the mode menu, just download the latest version from doom9
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 09:09 -
Samsung dvd-4155 DVD Player/recorder format problem
By jamesd1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th May 2009, 23:51 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 04:26
