  1. Well, the title says it all... anyone know if it is possible to play a DVD-R on the XBox if you have the DVD media kit from Microsoft? I've got the kit and a HS2, but have not been able to play anything besides shrink wrapped DVD's on the unit.
    Thoughts?
  2. I think you have to have a modchip for it to play dvd-r
    u may want to check out www.hackxbox.com
    good luck
  3. I went there and looked and found nothing about playing DVD-R's, but I will search at Google and under X-Box and mod chips to see if I can find an answer. You wouldn't think you should have to mod your X-Box just to play a movie.
  4. I presume your in the U.K The answer is that the X-box will play DVD-R's without being chipped. Yes you need the remote control which costs about £20.00. But remember you still need to burn with the right program and be using the right media...................''
  5. Do you know which programs work, I know you can't burn with NERO, what burning programs do you use and does have to be set to burn as a DVD video or a DVD-Rom, if rom can you use 1.50 or does it have to be the older 1.02 version in the UDF settings. What Media is the best.
  6. Xbox will play dvd-r
    I use memorex media
    encoder-tmpgenc
    author-roxio videopack 5
    burn with-instantcd+dvd
    I have a matshita dvd burner x1 p4 1gb of ram
    the dvd burner is a generic panisonic I THINK everything else is pretty standard stuff
    da PLUG
    ALLTHINGS VIDEO
