Hi Guys,
I've been trying to set up realtime recording to SVCD format & thought I would post my findings. Hopefully this will help others.
I tried PowerVCR2 Deluxe but I found this had a lack of PAL templates for SVCD. I then tried NanoDVR, this kept crashing when trying to capture in SVCD. My final try was with Intervideo winDVR2, this works fantastic for capuring to SVCD PAL format. It works like a video recorder. You can set a timer like a video player as well. The mpeg's produced can be burnt direct to CD-R or CD-RW using vcd easy.
In my opinion I would say Win DVR is the best for TV capture, any other opinions please post.
The capture card I'm using is a Avermedia TV Capture98.
Hope this helps others.![]()
Results 1 to 1 of 1
Good MPEG2 Capture Software
By mcg22 in forum Capturing and VCRReplies: 4Last Post: 26th Jan 2011, 13:36 -
mpeg2 50mbps capture questions
By the1selecta in forum Capturing and VCRReplies: 13Last Post: 30th Oct 2010, 22:22 -
What do I get for my needs - Mpeg2\Ac3 capture?
By Castor troy in forum Portable VideoReplies: 1Last Post: 20th Apr 2008, 18:56 -
MainConcept MPEG2 Capture using 4:2:2 profile
By wiseant in forum Capturing and VCRReplies: 0Last Post: 14th Dec 2007, 15:42 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 25th Aug 2007, 00:49
