Hello,
maybe someone here experienced the same problems than me and can help me.
I want to frame serve from Premiere 6.5 into TMPEG using Avisynth. I have installed the avisynth dll and the premiere plugins and the avs reader for tmpeg and everything seemed to work fine until I started the conversion. A message appeard "no function named ipcsource". I found out that in some versions of avisynth this function is located in avisynthex.dll, and this dll is present on my system, but I am not sure how to use it. does it have to be registered seperately or is it recognized by the avisynth.dll automatically? I had a sample avs script which contained an additional line compared to my avs file which only had the (ipcsource...) line which said load plugin"ipcserver.dll". I have no such dll file on my system and couldn't find one, so i tried to set the avisynthex.dll instead, but then it said "can't connect to server. frame server down?".
well, that's all the shit. anyone has a clou what may be wrong here?
regards,
NiteFlame
Results 1 to 1 of 1
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
programm which can make frameserving for Avisynth script
By Yury Perschin in forum Capturing and VCRReplies: 0Last Post: 20th Jan 2009, 11:19 -
frameserving movie from premiere pro cs3 to avisynth
By colin66 in forum Newbie / General discussionsReplies: 10Last Post: 29th Oct 2007, 07:47 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
