Hi all. Just got a DVR-105 and I am starting to transfer all my home videos to dvd. Loaded up virtualdub and cinfigured according to the guides and all went well. Everything worked and the video's looked great. Popped another into the VCR and went to capture, but now I am getting dropped frames out the wazu! I'm talking over 50 per 100 captured! I haven't changed a thing! I even the tried the first video I captured and it did it also now. What could have happened to suddenly casue this?
This is extremely frustrating, any help would greatly be appreciated!
Do you have your framerate set correctly. If you are in NTSC country this is 29.97fps, vdubs default is 15 so if you don't set it manually to 29.97 (and save it) you will drop just over 50% of the frames.
Thanks for the reply. I have my framerate set to 29.97. I loaded up Winproducer that came with the card and everything worked fine so I tried V-dub again, no dropped frames now, but my picture is tinted with a blue hue now! AGGGHHH.
Maybe a driver problem?
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 23:47 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 19:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
