Hi specialists![]()
Relatively new to VCD converting, I encountered a weird problem with
TMPGEnc today:
I tried to convert an AVI of @720MB to VCD/S-VCD but T reports an estimated file length of 1.9GB(!) I tried it both ways, manual configuration and via the wizard, by using the tutorials found here - same result.
GSPOT didn't find any errors or missing codec (nimo build8 installed).
Any suggestions?
Thank u very much in advance
Michael
Cologne/Germany
The size of the AVI is irrelevant, what matters is the length of the video. For VCD 1 minute = 10mb. So for a 1.9GB VCD you are looking at a video length of approx 190min or 3 hours 10 min. Does this sound right ?
Thatīs happen to me too but I solve that problem by open up the movie in Virtual Dub,then save the audio as an uncompressed wave.
After that just load up the movie in TMPGEnc in video source and select the uncompressed wave(Which is very huge)as audio source.
Hope that helps. -
@Craig
please correct me if I'm wrong...
I understand, that the VCD target will be bigger than the original AVI (GSPOT recognise it as a div3), but 3 times sounds weird to me. The movie has an entire length of approx. 3.5 hours devided in two parts of ca. 720MB.
That would mean I need 3 CDR-80 to watch the first 1:20h of the movie!?
@crack
I'll try to extract the audio ... -
Originally Posted by der_mac
If the movie is 3.5 hours long (210 minutes) converted to VCD this will be 2.1GB for the entire movie. You will have to split it to fit onto 3 discs. -
You guys are great !!
I got it! It was my fault, to ignore the VBR problems of TEMPGEnc because I didn't exactly know what this means, lol
I extract the audio layer and everything works fine now
Thanks a lot
AVI file length
By RonNYC in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2012, 17:47 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
Image Grabber reads all file extentions except wmv...Why?
By King_Tut in forum Capturing and VCRReplies: 9Last Post: 20th May 2009, 15:00 -
TMPGEnc Issues with length of movie?
By doctorgonzo in forum Video ConversionReplies: 1Last Post: 11th Apr 2009, 10:30 -
file length problem
By danboy775 in forum Video ConversionReplies: 1Last Post: 30th Mar 2009, 08:21
