Pioneer 454 - plays region 1 and 2 in colour when connected directly via SCART, but when using the LINE 3 SCART on my Sony VCR, region 1 discs come through in black and white - region 2 are fine.
Any got any ideas or suggestions as to how to fix this?
That is because your VCR cannot handle an NTSC signal input. In the UK most VCR's will play both NTSC and PAL tapes but can only record from a PAL signal. If you input an NTSC signal you will have the problem of a black and white picture. You may also have problems with macrovision (although if your region 1 discs are ok, this would appear not to be the case). Try a PAL-NTSC converter this should solve the problem, some will also remove macrovision protection.
So can I get a SCART input/output NTSC/PAL convertor of decent quality in the UK?
Help most appreciated. -
These unit generaly don't use scart connectors, so you would need a scart-rca converter.
http://www.scancom.ltd.uk/products/standards_converters1.htm
http://www.gthelectronics.com/
How to put black colour on screen without re-encoding?
By swalih in forum EditingReplies: 6Last Post: 16th Feb 2012, 03:44 -
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 08:39 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 13:00 -
Colour Avi (or mpg) to black and white
By cawright1 in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 06:00 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 18:10
