HI,
I've just downloaded Die another day(xvid). When i play it in windows media player i see a blurry picture but WITH sound. now i downloaded a xvid player and i get a perfect picture but with NO sound.?????
in vdub i get a good picture but gives an ACM sound error. what the hell that means? and tried to save the sound serperate from the picture, and that works. but when i put the both back together. same problem all over again.
Please help.
Results 1 to 18 of 18
Sounds like you have a DirectShow filter and can play but not edit.
ACM refers to the sound, try installing an AC3 codec.
Try installing
Moonlight Odio Dekoda, Universal AC-3/MPEG Audio (Layer 1/2/3) Decoder -
Hi,
I had exactly the same problem until just !!
Go here :-
http://www.digital-digest.com/dvd/downloads/ac3filter.html
then download the top one of the two options there :-
ac3filter_0_63b.exe
i installed it just and i have now got sound YIPPEEEEE
cool , am glad for two reasons
1. It worked
2. i am not the only one who struggles with these codecs !! -
Shame you never used Moonlight Odio, then you would have even less problems in time to come.Originally Posted by kipper9999
I would have used it, but when you try and download it, it asks you for your e-mail add and password !
I tried a few times , even from links elsewhere, always going to the same download page.
If you have a e mail and password great, please mail it me at :-
ant_bcfc@btinternet.com
Maybe i'm doin something wrong !!
Cheers
Ant.. -
You clicked the wrong link
http://www.moonlight.co.il/download.htm
Moonlight Odio Dekoda DirectShow® filter, binary (71,855 bytes, ZIP)
HTTP Download, U.S. Primary (it is recasting) password
HTTP Download, U.S. Secondary Free
HTTP Download, Russia -
K i'm having problems playing Xvid, namely die another day and the bourne identity...
Could someone list the necessary they downlaoded to play the files? -
Test your system, see whats missingOriginally Posted by Ewlesy
http://www.vcdhelp.com/forum/userguides/135217.php -
Ha,
thanks for the link,
now die another day will not run comes up with an error !!!!
Try if you want, but i would NOT RECOMMEND downloading that moonlight crap
Ant..
Have even tried to un install it and that failed -
i am feeling very lucky
As i am running XP Pro, it has a "system restore" built in.
Basically it means that as long as you have it set up correctly, it can return to a pre determined day
luckily it had recorded yesterdays set up ,
i have restored it and it was successful. Thank god
Die another day works again now !!!
i will NOT be installing moonlight EVER AGAIN -
Moonlight is not crap, it only looks that way on a crap systemOriginally Posted by kipper9999
Thank you kipper9999 for the GOOD link to a real .exe easy usable codec!
I don't understand why this KingJohn is always f... us with his Odiostuff codec. It was not working for me. Even if it does work well, why such a "you should better use this one", etc. ??!!
Anyway... cheers & enjoy divdxvidcdwhatever
Bruno, 30
Brussels, Belgium -
Its because I know there will be other problems later with other programs, but if you like to learn the hard way then thats find with me !
Well it works for everyone else, its hardly Monlights fault if you dont know how to use it...It was not working for me
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 13:15 -
Problem with convertion to xvid...
By zovx in forum Video ConversionReplies: 11Last Post: 11th Feb 2010, 07:43 -
MKVTools and Xvid problem
By Geiger9 in forum MacReplies: 5Last Post: 18th Jun 2009, 16:34 -
Problem with XVID
By s2dat in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2008, 12:25 -
joining xvid problem
By aerial25a in forum EditingReplies: 2Last Post: 23rd May 2007, 04:14
