Hi,
Im trying to make a backup of my 'robbie at the albert DVD' to DVD-R
firstly I used DVD Decypter 3.1.2.0 to rip it.
Next up DVD2AVI was used to seperate the sound and video. It told me it had:
An Aspect ratio of 16:9
PAL format & was 20fps ????
After putting it through TMPGEnc, the video came out Crisp but jerky.
Any ideas how to get this to play properly as a backup
Many thanks
Sounds like a non-standard DVD by some cheap publishing company. Are you backing up to DVD-R or CD-R? If DVD-R I suggest to not recompress the video. If CD-R, in TMPEnc under the "Advanced" tab check the box that says "Do not frame rate convertion". Convert and burn, see if it works. Might want to encode 5 min to then burn to see if it works, so you don't waste 10 hours.
Hope this helps. -
Or better yet. Make sure that ForcedFilm is not checked in DVD2AVI. That will cause a PAL DVD to think that it is like 20fps. I don't know why I didn't think of that before! If it isn't then just use my previous post.
Hope this helps even more. -
Thanks alot for the quick resonse
Im going to try those ideas out and I'll let you know how I get on.
Many thanks -
DivExpert,
Just removed the forced film option in DVD2AVI and instantly when I started to process it, 25 fps was reported instead of the 20 fps that I had before.
Im sure this will cure it mate.
Thanks again.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
I can't reduce the size of a file using AutGK - "no fps"
By HartsVideo in forum EditingReplies: 38Last Post: 3rd Jan 2009, 22:02 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
