When I do the VCD header trick Nero and VCDeasy (or the muxing maybe?) seems to set the bitrate to half of the original and after burning the movie gets twice as long and stutters a lot. Ex: A 4 minute movie gets 8 minutes long. MPEG tools in VCDeasy gives this information:
Before header trick:
MPEG2, PlayingTime=244.793s, Bitrate=2820kbps, PtsOffset=0726s, 36568 packets
Video Stream: Motion Video, 480x480, 29.97003fps (NTSC), 2520kbps
Audio Stream: Audio Standard MPEG layer2 Stereo, 44100Hz, 229376bps
After header trick:
MPEG1, PlayingTime=244.777s, Bitrate=1411200bps, PtsOffset=0833s, 36594 packets
I've created the mpeg2 with the SVCD NTSCfilm template in tmpgenc.
Anyone knows how to fix this?
Hence "trick".
It doesn't work for everything. If your player supports standard SVCD, you should just make that. If it supports neither SVCD or an XVCD with a SVCD-spec MPEG muxed with the VCD header, then I suggest trying XVCD with off-spec MPEG-1 files (or god forbid) a standard VCD.
VCDXMINFO isn't that good at determining the specs of funny encoded/muxed MPEG files but this isn't really part of your problem.
Regards.Michael Tam
w: Morsels of Evidence
VCD vs Half-D1 vs Low bitrate full-D1
By nharikrishna in forum Authoring (DVD)Replies: 44Last Post: 6th Feb 2011, 23:50 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 12:34 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36
