I have tried everything! and even with max compression all i get is 250mb for 1 min of video!
Whats going on?
It would help if you would let us know the settings you are using.
In my case 1 minute = 100 Mb MJPeg at a resolution of 352 * 288 with 25 fps and a compression ratio of 3.00
If you are capturing at 720 * 576 you might end up with 250 Mb so that would be normal depending on the settings used.
After encoding to MPeg-1 or MPeg-2 you will get much smaller files.
Rene.
I've a sneaky feeling you aren't actually compressing the video at all... and you certainly aren't using MJPEG as changing the quality setting would certainly have an effect on the file size.
I had a similar issue when I was using Virtual Dub. There are actually two screens where you can set and configure the compression codec and you have to do it in both. It also seemed to deselect back to uncompressed whenever I changed any other settings.
Start from scratch and go through each settings menu, even the ones not in the guide and configure accordingly. Before you capture just recheck the video settings to ensure MJPEG is still selected.
Good luck with this
Dave B -
I figured it out finally!
When i cahange codec settings i must do it in the normal screen (shift-c) and in the compatability screen(c) i dont know why but it works!
Convert to MJpeg
By gmellow in forum Video ConversionReplies: 18Last Post: 29th Jan 2015, 05:21 -
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 15:03 -
MJPEG export
By vizion in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2011, 12:52 -
Quicktime MJPEG to XviD?
By udaykhan in forum DVD RippingReplies: 10Last Post: 1st Apr 2009, 10:33 -
MJPEG Testing
By adambklyn in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 01:04
