    Portland OR/Hita Japan
    Is there any possible way of adding variable framerate to any of the programs(FFmpegX, Afropic, Mediapipe)?
    If someone could do that, our synching issues would be abolished.
    Qshartle
    "Good Luck 007"
    In Memory of Desmond Llewelyn
  2. Why don't you just use ffmpegX and choose the "QT decode" option? I've made (X)VCDs, (X)SVCDs, and CVDs with this method - all perfectly in sync.
    Hmmmm.....
    What framerate did you choose?
    "Good Luck 007"
  4. NTSC (29.97). They're all NTSC DVDs.
