I have a very simple question this time. I have an AVI file that is 640x272......so it's a bit panoramic...I want to burn it onto VCD but i don't want to distort and force the size to 352x240, so is there a way to stick maybe a black band on the top/bottom, so it'll play in that long horizontal size??
THANKS IN ADVANCE
~SIDESHOWFREAK
If you keep the aspect ratio of the original clip while converting to vcd in TMPGenc you will get the bars on the top and bottom. How To's are to the left. Check them out. They are really helpful. Hope it helps.
HEY thanks for replying....
However i did encode the file using TMPGenc and everything seems to be fine, but when i use Nero to burn my VCD, it tells me that the file needs to be reencoded...why is that? Should i reencode?? or just go ahead with the burning?
thanks,
~SIDESHOWFREAK
Mixing AVCHD with SD DV-AVI, frame size & arrangement question...
By sdsumike619 in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2012, 22:18 -
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 15:45 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 00:21 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 18:43
