Hi all, I am fairly new to making VCD's. I am mainly intrested in making Anime ones, however i have noticed that on some (most) the subtitles are out of the screen (i.e. you cant read them). Does anyone know how to resize the mpeg or another way of making sure that I can always see the subs correctly? Thanks!
MD
use vobsub and virtualdub
you'll see a vobsub filter in the video filters of virtualdub. -
hi
try these settings with panasonic mpeg encoder, fansubbed anime is in PAL so you have to make it in 320 x 240 so its compliant with nero and also helps so it doesnt artifact which I get a lot in TMPG. anyway under special setting set black to top 10, bottom 15, left and reight 5. this gives you boarders on where its usually cropped for TV.
save your settings, encode and just burn with nero, works great on samurai deeper kyo anyway but should be the same on all since it the TV I think that messes it up >_<
Restouring Anime
By LeoHenrique in forum RestorationReplies: 55Last Post: 21st Aug 2011, 13:48 -
Anime encoding help
By carasy in forum Video ConversionReplies: 3Last Post: 28th Nov 2010, 19:07 -
Where to download free srt subtitles (Mostly for anime)
By lelouch283 in forum SubtitleReplies: 3Last Post: 19th Oct 2010, 07:53 -
streaming anime no subtitles showing half the time/off screen
By thewhiteboy23 in forum Newbie / General discussionsReplies: 17Last Post: 18th Oct 2009, 13:46 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 16:31
