Hi everyone, im a newbie to making svcd's but ive made a couple thanks to the guides on this site. The only problem is that they dont say which is the best settings to use when making svcd's in TMPGEnc.
Ive followed this guide, but im sure there is a way to even make my divx rips look even better on my tv.
http://www.vcdhelp.com/tmpgencsvcd.htm
Thanks,
Mike
The SVCD Can't look BETTER then the original. What are you using for the BITRATE when your encoding??Originally Posted by mikeweb
Well i guess some stuff that I would like to be answered is
What should I set the "Aspect Ratio" to? 1:1 (VGA), 4x3 525 line, ect....
What should I set the "Rate Control Mode" to? Constant bitrate, 2-pass (VBR), ect...
I always did the "contant bitrate" thing, but i heard that it isnt that good. -
well there's nothing WRONG with Constant Bitrate ( CBR ) it's not evil or anything like that
It's just it may not be the most efficient that's all
I'm not going into a CBR / VBR explanation here it's already detailed on this site
personally I'm a 2/3 pass VBR person myself
but aspect ratio stick with 4:3 "normal" for most things
Settings TMPGEnc to FFMpeg
By Nologic in forum Video ConversionReplies: 0Last Post: 5th Apr 2012, 23:15 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
Help with TMPGEnc 4.0 XPress Settings
By mister_to_you in forum Video ConversionReplies: 0Last Post: 20th Jun 2008, 10:01 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
