Just picked up the Pioneer DVR-105, not tried to burn a DVD as yet but having major problems trying to burn some bin/cue and img files. I keep getting a "failed to send cue sheet" or "cue sheet rejected" or similar depending on the program I try (Details below). I have a new P4 2.5/768 with 2x120GB drives running XP Pro SP1 so there is lots of clean disk space. ASPI 4.6 installed and working properly.
I'm using Nero 5.5.10, tried CDRWIN and Alcohol 120, fireburner, blindwrite...pretty well everthing else as well. I can burn some bin/cue files but not others. I came across a posting (that I can't find) where the guy was describing much the same problem and said it had something to do with extended cue files. Not sure what this means but I have attached one of the cue files that has been causing me grief.
I can burn these fine on my old 98se machine with either a Sony and Matushita 8x CD burner but the damn 105 is spittingthem back at me. At this point I don't know if it's XP, the burner or some other setting that I am missing.
Anyone else having this problem? Anyone have any idea what it could be?
TIA for any help you can offer.
Rileyman
Here's some detail - sorry for the wack of info but this is driving me crazy - two years coaster free and now my coaster stack is the same size as my blank stack...please help !!!
Here's one of the cue files - and yes it's in the same folder as the bin
FILE "whatever.bin" BINARY
TRACK 01 MODE2/2352
FLAGS DCP
INDEX 01 00:00:00
TRACK 02 MODE2/2352
FLAGS DCP
INDEX 00 00:04:00
INDEX 01 00:06:00
INDEX 02 00:06:01
INDEX 03 19:47:10
INDEX 04 44:31:73
INDEX 05 68:27:28
Here's the error log from Nero
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/25/2002 4:34:54 PM
Nero Version: 5.5.10.0
Recorder: <PIONEER DVD-RW DVR-105> Version: 1.21 - HA 1 TA 0 - 5.5.10.0
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <PIONEER DVD-RW DVR-105>Version: 1.21 - HA 1 TA 0 - 5.5.10.0
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-105 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.1a vdevax Port 2 ID 0 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 767MB (785888kB)
Free physical memory: 524MB (536640kB)
Memory in use : 31 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
5.1.2003
CueSheet
10:03:44 PM #1 Phase 90 File dlgbrnst.cpp, Line 1649
Buffer Underrun Protection activated
10:03:44 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
10:03:44 PM #3 Text 0 File Burncd.cpp, Line 3790
Turn on Disc-At-Once, using CD-R/RW media
10:03:44 PM #4 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (original item values)
0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
2 indices, index0 (150) provided
original CD pos #0 + 300 (300) = #300/0:4.0
relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
6 indices, index0 (150) provided
original CD pos #0 + 1 + 88584 + 111363 + 107655 + 50189 (357792) = #357792/79:30.42
10:03:48 PM #5 Text 0 File DlgWaitCD.cpp, Line 202
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 358241 (79:38.41)
10:03:48 PM #6 Text 0 File DlgWaitCD.cpp, Line 207
Write in overburning mode: FALSE
10:03:48 PM #7 Text 0 File DlgWaitCD.cpp, Line 1419
Recorder: PIONEER DVD-RW DVR-105;
CDR code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited
ATIP Data:
Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
10:03:48 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 811
Prepare recorder PIONEER DVD-RW DVR-105 for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x20 Session Closed, CD fixated
Tracks 1 to 2:
TRM_DATA_MODE2_2336, 2336/0x0, ISRC "", FilePos 0 350400 1051200
TRM_DATA_MODE2_2336, 2336/0x0, ISRC "", FilePos 1051200 1401600 837203712
10:03:48 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 659
Setup items (after recorder preparation)
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 300 blocks [PIONEER DVD-RW DVR-105 ]
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 357792 blocks [PIONEER DVD-RW DVR-105 ]
10:03:48 PM #10 Phase 36 File dlgbrnst.cpp, Line 1649
Burn process started at 16x (2,400 KB/s)
10:03:48 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1952
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
10:03:48 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1952
Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #450
10:03:48 PM #13 Text 0 File Mmc.cpp, Line 12522
StartDAO : CD-Text - Off
10:03:48 PM #14 Text 0 File Mmc.cpp, Line 17129
Set BUFE: supported -> ON
10:03:48 PM #15 SCSI -1067 File Cdrdrv.cpp, Line 1189
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0231E000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x00
CDB Data: 0x5D 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x50 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x26 0x00
10:03:48 PM #16 Text 0 File Mmc.cpp, Line 12780
CueData, Len=80
41 00 00 24 00 00 00 00
41 01 00 20 00 00 00 00
41 01 01 20 00 00 02 00
41 02 00 20 00 00 06 00
41 02 01 20 00 00 08 00
41 02 02 20 00 00 08 01
41 02 03 20 00 13 31 0a
41 02 04 20 00 2c 21 49
41 02 05 20 00 44 1d 1c
41 aa 01 24 00 4f 26 2a
10:03:48 PM #17 DVDR -1067 File ThreadedTransferInterface.cpp, Line 1397
Invalid field in parameter
10:03:48 PM #18 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1397
Could not perform start of Disc-At-Once
10:03:48 PM #19 Phase 38 File dlgbrnst.cpp, Line 1649
Burn process failed at 16x (2,400 KB/s)
10:03:48 PM #20 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Here's a sample CCD that I'm having trouble with
[CloneCD]
Version=3
[Disc]
TocEntries=4
Sessions=1
DataTracksScrambled=0
CDTextLength=0
[Session 1]
PreGapMode=1
PreGapSubC=0
[Entry 0]
Session=1
Point=0xa0
ADR=0x01
Control=0x06
TrackNo=0
AMin=0
ASec=0
AFrame=0
ALBA=-150
Zero=0
PMin=1
PSec=0
PFrame=0
PLBA=4350
[Entry 1]
Session=1
Point=0xa1
ADR=0x01
Control=0x06
TrackNo=0
AMin=0
ASec=0
AFrame=0
ALBA=-150
Zero=0
PMin=1
PSec=0
PFrame=0
PLBA=4350
[Entry 2]
Session=1
Point=0xa2
ADR=0x01
Control=0x06
TrackNo=0
AMin=0
ASec=0
AFrame=0
ALBA=-150
Zero=0
PMin=70
PSec=37
PFrame=6
PLBA=317631
[Entry 3]
Session=1
Point=0x01
ADR=0x01
Control=0x04
TrackNo=0
AMin=0
ASec=0
AFrame=0
ALBA=-150
Zero=0
PMin=0
PSec=2
PFrame=0
PLBA=0
[TRACK 1]
MODE=1
INDEX 0=-150
INDEX 1=0
And here's the Log from Alcohol 120% when trying to burn the ccd above
===---------------------=== System Information ===---------------------===
Windows XP Professional 5.1 Service Pack 1 (Build 2600)
Processer info : Intel(R) Pentium(R) 4 CPU 2.53GHz (2538MHz)
Memory Available to Windows: 785,888 KB
Devices control interface : Default Driver Control Interface
===-------------------=== Alcohol 120% Information ===--------------------===
File Name : C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name : Alcohol Soft Co., Ltd.
Description : Alcohol 120%
Original : alcohol.exe
Product : Alcohol 120%
Trademarks : Alcohol Soft Co., Ltd.
Copyright : Copyright (C) 2002 Alcohol Soft Co., Ltd.
Version : 1.3.5 ( Build 1112 )
Date : 2002/11/13
File Name : C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Description : Alcohol virtual device control library
Original : alcoholx.dll
Product :
Trademarks :
Copyright : Copyright (C) Alcohol Soft Co., Ltd. 2002
Version : 3.26.0 ( Build 0 )
Date : 2002/11/11
File Name : C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description : Alcohol Software Device Capabilit Library
Original : devsupp.dll
Product : Alcohol Software Device Capabilit Library
Trademarks :
Version : 2.2.1 ( Build 1112 )
Date : 2002/11/13
===--------------------=== User Information ===----------------------===
User Name : vvvvv
Company Name : vvvvv
Registered User ID : vvvv
===-------------------=== Devices Information ===--------------------===
(DPIONEER DVD-RW DVR-105 (1:0)
(GAXV CD/DVD-ROM (2:0)
===---------------=== Devices Detail Information ===-----------------===
Note: This information is provided by the unit, it might be inaccurate.
This software does not use this information!
Report (DPIONEER DVD-RW DVR-105 (1:0) Detail Information.
Vendor ID : PIONEER
Product ID : DVD-RW DVR-105
Firmware Version : 1.21
Host/Target ID : 1/0
Removable media: YES
ANSI Version : ATAPI SFF8090
Respone Data Format : 02H
CD-R Read/Write : YES/YES
CD-RW Read/Write : YES/YES
Read CD-R fixed Packet : YES
Test Write : YES
DVD-ROM Read : YES
DVD-R Read/Write : YES/YES
DVD-RAM Read/Write : NO/NO
Audio Play : YES
Composite Audio and Video Data Stream : NO
Digital output(IEC958) on port 1 Supported : NO
Digital output(IEC958) on port 2 Supported : NO
Mode 1 Form 2 : YES
Mode 2 Form 2 : YES
Multi-Session : YES
BUF : YES
CD-DA Commands supported : YES
CD-DA Stream is Accurate : YES
R-W Supported : NO
R-W De-interleaved & Corrected : NO
C2 Pointers Support : NO
ISRC Supported : YES
UPC Supported : YES
Read Bar Code : NO
Lock media into the drive : YES
Currently drive Lock state : Unlocked
PreventJumper : NO
Eject Command : YES
Separate volume leavels : YES
Separate channel mute : YES
Changer Supports Disc Present : NO
Software slot selection : NO
Side change capable : NO
P through W in Lead-In : YES
===------------=== Source Disc/Image Information ===----------------===
Type : CloneCD Image file
Path : C:\Program Files\nbpro\DOWNLOAD\alt.binaries.cd.image\cw.sxl2
cw.sxl2.img
cw.sxl2.sub
Session: 1
Track: 1
Session 01 :
Track 01 : Mode 1, Length : 317631(620.4 MB), Address : 000000
===------------=== Recording Progress Detail Log ===----------------===
PM 08:31:05 Processer info : Intel(R) Pentium(R) 4 CPU 2.53GHz (2538MHz)
PM 08:31:05 Memory Buffer using size: 128 MB
PM 08:31:06 Image file loading : C:\Program Files\nbpro\DOWNLOAD\alt.binaries.cd.image\cw.sxl2 \cw.sxl2.ccd
PM 08:31:06 Source Info : Session : 1, Track : 1, Length : 620.4 MB / 070:35:06
PM 08:31:06 (DPIONEER DVD-RW DVR-105 (1:0) : Recording Method/Speed
PM 08:31:06 Recording - DAO / SAO - 16X (2400 KB/Sec)
PM 08:31:06 (DPIONEER DVD-RW DVR-105 (1:0) : BURN-Free activated
PM 08:31:06 (DPIONEER DVD-RW DVR-105 (1:0) : [SEND CUE SHEET ERROR]
CDB : 5D 00 00 00 00 00 00 00 20 00 00 00
D:-0--1--2--3--4--5--6--7--8--9--A--B--C--D--E--F--
41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00 41 AA 01 14 00 46 25 06
S:KEY - 05/26/00 - "Invalid Field In Parameter List"
PM 08:31:06 (DPIONEER DVD-RW DVR-105 (1:0) : Recording failed!
PM 08:31:06 Error message : [05/26/00] - Invalid Field In Parameter List
PM 08:31:06 Image file loading aborted!
PM 08:31:08 Something is wrong with the recording procedure!
Please check the log file and report any errors to Technical Support.
I didnt read ur entire post,just tooooooooo damn long
apsi 4.6 is NEVER GONNA HELP U... u need 4.71 available
from adaptec, also look in tools, 4.6 is for windows2k i think
when u d/l 4.71 or 72, theres a aspi checker,sp1 isnt the
answer either, cause it just messes things up, try to uninstall
it to see what happens, juist kidding, itll kill ur system.... -
Thank's I'll look at that. I find it odd that I can burn the same files with ASPI 4.6 on 98SE with no trouble and normal or short cue sheets on this machine with no trouble, it's these extended cue sheets that seem to be the issue - does 4.71 address this or are you just thinking it's better to stay current? I can't find anything to suggest it's an ASPI issue.
Using Adaptec's ASPI layers on my sytem has done nothing but screw things up. I had a few programs (including cdrwin) that whined about not having an aspi layer, so i just copied the aspi dll from Nero into the offending programs' folders and they worked!
That said, it sounds like your problem lies elsewhere. I've never seen the bin/cue issue you mention, and i have a 2.8 ghz p4 setup with the older a03 Pioneer burner as well as a 48x Plextor cd-rw. -
Snarfo - I would agree with you, don't think it's an ASPI issue either so I'll probably try that as a last resort..hopefully someone has seen this problem before - and solved it!!!
Pioneer DVR 520H Error Messages
By Sweetow in forum DVD & Blu-ray RecordersReplies: 6Last Post: 16th Jan 2009, 00:18 -
JPEG to AVI (or MPEG2) via timing cue-sheet?
By NetRodent in forum Video ConversionReplies: 0Last Post: 31st Aug 2008, 10:49 -
Pioneer DVR-545HX --- HDD Error
By der Heiko in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Aug 2008, 10:53 -
cue sheet problem
By Snowcrystal in forum AudioReplies: 2Last Post: 2nd Sep 2007, 13:29 -
Illegal Disc Error w/Pioneer DVR-105 in Nero
By Quadzilla in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 13:23
