What problems do you see in this method of capturing a television program?
Open virtualdub
Capture mode
Set to 29.97fps, 480x360, No filters, 44hz uncompressed audio
Compression set to MPEG-4 VC2, Data rate 6,000 (that's the max)
F6 to capture/record (it will record video at about .75 MB/s)
Thanks for reading. I didn't notice any difference by using MPEG-4 VC2 from the lossless Huffyuv (even though I'm sure there is). Can anyone explain the problems with this method, or perhaps suggestions?
For my final capture I:
Use filters
Use the XviD compression tool @ 93-97 quality and files come to 150-250 MB on a 22 min video
Results 1 to 1 of 1
Best capturing method from VHS to digital format with highest quality?
By jbloggs in forum Newbie / General discussionsReplies: 10Last Post: 14th Nov 2015, 03:36 -
Capturing from LaserDisc for DVD burning - best method?
By Xoanon in forum Capturing and VCRReplies: 11Last Post: 25th Apr 2012, 22:51 -
Best method for capturing VHS?
By blud in forum Newbie / General discussionsReplies: 7Last Post: 6th Apr 2012, 04:06 -
Is there a better method?
By quxote in forum Authoring (DVD)Replies: 4Last Post: 24th Nov 2009, 15:32 -
DV to H.264 Resoultion Question-> 480x360 or 480x320???
By tarrickb in forum Video ConversionReplies: 1Last Post: 8th Aug 2008, 18:13
