    Dec 2002
    netherlands
    hey people
    i have a strange problem, i downloaded a .avi file with sync video and audio. When i split this movie with virtualdub, the 2 files are running out of sync.
    Before virtualdub opens the original movie it gives me an error for vbm audio. I tried to strip the audio file in a wav file and the i put it back in the movie but then it was about 2 gig so i try to compress the wav file but that didn't work out.
    can someone please help me
  2. Banned
    Jun 2001
    UK
    You should read what that warning says
    VBR (Variable Bit Rate) its warning you that you should decompress....
    Anyway, don't use the normal Vdub use "vdub-mp3-freeze.exe" it handles VBR without the same problems.
    Why do you want to split it ? Convert with TMPGEnc then split it later !!
    See also
    http://www.vcdhelp.com/forum/userguides/117930.php
    Dec 2002
    netherlands
    well i gonna try this mp3-freeze
    i want to split the avi because i don't wan't to convert i just burn the avi
    Dec 2002
    netherlands
    thanks kingjohn
    i tried this mp3 freeze and now it's working
  5. Banned
    Jun 2001
    UK
    Glad you got it sussed out
    Dec 2002
    netherlands
    maybe you can watch my newtopic also "another sync problem"
    again thanks for your help
